Engrave V-shaped Text
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I use Inventor to make models to 3D print. In 3D printing, higher layers can actually overhang empty space, up to an angle of something greater than 45 degrees, without requiring support structures be printed. That's good, because supports mar the surfaces they support.
So I'd like to engrave text on a face that will be facing the build surface. To avoid supports, I need to make the engraving V-shaped (triangular). Rather than equilateral, I'd need it to be isosceles, because sharp angles between parts of a letter can steepen the slope when engraving at a particular angle. So I'd want to make the "trench" somewhat deeper than it is wide.
I've tried to do something with a sweep, but I can't find a font that will let me use a sweep. Even then, I'm not sure how easy it would be.
What's the best way to proceed?
