Hi Tommyboy1986,
I don't have any other links to fully dimensioned assembly projects, but if you join one of the model engine hobby websites you can find plans for engines that have fully dimensioned 2D drawings for the entire engine assembly.
If you're open to projects other than engines, you can find a lot of fully dimensioned woodworking projects that can offer a challenge. Often a local library is a good source for wood working project books, or possibly metal working projects.
Popular Mechanics has some projects:
http://www.popularmechanics.com/build-these-now-plans/
https://www.google....popular+mechanics+project+plans
If you're just looking for more modeling challenges check these links out:
There are some challenging parts to model ad this link, just download the zip file and look for the PDF for each challenge:
http://www.design-excellence.com/worldcup/worldcupfiles.asp?offset=0
Grabcad challenges (use the finished challenges as practice, or try your hand at the active challenges):
https://grabcad.com/challenges/active
https://grabcad.com/challenges/finished
I hope this helps.
Curtis
