Inventor Forum
Embossing on a solid vase
13 REPLIES 13
Message 1 of 14
Cameron_Greatorex
1207 Views, 13 Replies
Cameron_Greatorex
I've created a vase for a project which is made out of a simple spline and a revolve. I'm starting to emulate the patterns - first as a 2D sketch then projected as a 3D sketch. The reason being, the emboss function didn't work with a 2D sketch and according to the forums embossing is only available for flat, cylindrical or truncated surfaces.
What are my options? Is there a way to turn the 3D sketch into an offset surface and extrude it from there? I almost never use 3D sketches.
Any help would be greatly appreciated.
Tags (2)
Labels (1)
13 REPLIES 13
Message 2 of 14
JDMather
Can you Attach your *.ipt file here?
Message 3 of 14
Cameron_Greatorex
Sure. Thank you for taking a look at it.
Message 4 of 14
Cameron_Greatorex
I used the email reply function, but I'll post here just incase.
Thank you for taking a look at it JD!
Message 5 of 14
j.palmeL29YX
Attached an example to show a principal solution. Of course it must be refined with the correct dimensions. The main idea is to use a bended part feature...
Jürgen Palme
Jürgen Palme
Message 6 of 14
Cameron_Greatorex
Wow. Thank you for doing this. I can make sense of about half of what you have done and how you did it. Is it possible for you to share a screen capture so that the community can document this process? I am sincerely grateful for your help. If anyone would like to suggest a further simplified solution they are welcome to, but for now I am going to accept this solution and pray that I can recreate it (there are about 3 more sketches that I have to do with the same technique).
Message 7 of 14
Cameron_Greatorex
I've just tried replicating your steps with my sketch but the part won't bend with the same parameters that you had. I converted your sketch into construction geometry and just added my own on top. It's not a problem integrating it throughout the construction tree but gets stuck with just one iteration of mine when it is time to bend. So close!
Message 8 of 14
j.palmeL29YX
@Cameron_Greatorex wrote:
So close!
Post your current dwg ...
Jürgen Palme
So close!
Jürgen Palme
Message 9 of 14
Cameron_Greatorex
Thank you 😅
Thank you 😅
Message 10 of 14
JDMather
Post your current *.ipt file.
Message 11 of 14
Cameron_Greatorex
Here you go. It just won't bend for some reason 🤔
Message 12 of 14
j.palmeL29YX
The bend line must touch or cross the volume. Your Line (the sketch plane) is a little away from the volume.
(see attached image).
(and sorry for my error above: I wrote dwg instead of ipt, excuse me ... thanks to @JDMather for the correction)
Jürgen Palme
Jürgen Palme
Message 13 of 14
Cameron_Greatorex
You da man! Thank you Jürgen. All I have to do is emulate this for 3 more patterns and with any luck....I will make an art historian a very happy man!
If I can help you in any way, just let me know.
Thank you so much!
Thank you so much!
Message 14 of 14
Cameron_Greatorex
I just wanted to share the final result with you guys. Thank you so much for the help!
