I'm looking for an elevation marker to add to an Inventor drawing, I need something similar to what is currently available in AutoCAD's design centre. Does anyone know if there is one available in Inventor 2013 ?
You could create your own sketched symbol. see this pdf
http://download.autodesk.com/us/inventorprofessional/pdf/SketchedSymbols_stacking.pdf
So Inventor does not have a library of symbols for use like in AutoCAD then ? Thanks for your PDF link, to me it seems like placing an elevation symbol (for example) into a drawing should take seconds without the need to spend unnecessary time creating the symbol myself ? ? It would be good to see Autodesk address this one for the next release.
create it once in your template file and it will be there everytime you use that template to create a drawing.
You can insert acad drawings into a sketch. So you wouldn't even have to draw it. Just save what you want in autocad then import it into inventor.
Thanks yes, I still think the whole idea of a standard annotation and architectural symbols library being completely absent from Inventor needs addressing - a symbols library should be available as standard with the option to add to this with custom sketched symbols as you have suggested.
I see your point but inventor is a mechanical design tool, not architectural. Maybe the factory design package or revit it would have the symbols your looking for, just a guess.
You can create your own level symbol using a sketched symbol, store it locally and share with your other computers.
I reckon, this might be the easiest and fastest way for you to solve this problem.
You can use sketched symbols for many purposes and I think learning this technique really helps you in the long run.
I know this is an old post but hopefully this helps new people searching for the solution for this question!
