Inventor Forum
elbow development
9 REPLIES 9
Message 1 of 10
2424 Views, 9 Replies
elbow development
Dear All,
I am facing problem with elbow unfolding. I have made elbow in part modeling using swipe command.
That elbow is going to fabricate on shell find attachment for the same.
I have to make elbow development for the fitting on shell.
I made elbow in part model and convert in sheet metal and tried with rip commane but it not working.
I tried with rip command but it not working.
Could  you help me ?.
Thanks and Regards,
Datta Indalkar.
9 REPLIES 9
Message 2 of 10
mpatchus
Create the elbow using the CONTOUR ROLL command.
See attached part.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 10
Paul-Mason
SEE http://forums.autodesk.com/t5/Autodesk-Inventor/How-to-use-sweep-commantd-in-sheet-metail/m-p/378386...
Inventor 2025 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 4 of 10
Kindly save your file in lower version. I have Inventor porfessinonal 2011.
Thanks and Regards,
Datta Indalkar.
Message 5 of 10
mpatchus
Not possible to save files as a previous version in Inventor.
Inventor 2025 Beta
Message 6 of 10
luiww
Wonder if one can really flat pattern from contour roll.  The flat pattern is shown in rectangular shape and yet one would find it difficult to accept that the rectangular shape can be rolled to form a hollow elbow.  Maybe we should not agree fully with what the software indicates.
Message 7 of 10
Paul-Mason
in reply to: luiww
I,m just wondering if this is some sort of School/Collage assignment?
In the past few days I've seen 3 or 4 post on similar lines by different people.
TOP & BOTTOM IT IS IMPOSSIBLE TO FLATTEN THIS TYPE OF PIPE ELBOW INTO A FLAT PATTERN even in the days of drawing boards and pencils we could not do it.
Inventor 2025 Pro
HP Z420 workstation
Message 8 of 10
luiww
Using mathematics, I think we could flatten it.  Lets divide the circumference into sections and then calculate the arc length of the arc for that section.  On a piece of paper, simply lay the lines hortizontal with the computed arc length in the x-direction and circumference in the y-direction.
Message 9 of 10
JDMather
in reply to: luiww
Your right - it could be done on drawing board with calculations and knowledge of the material and process.
Inventor cannot create correct flat pattern for this shape.
Message 10 of 10
Dear Friend,
Thank you very much for your support. I was really sturgilin with this development of elbow. but by counter roll it is working.
Once again thaks.
Thanks and  Regards,
Datta Indalkar
