Inventor Forum
Editing files
5 REPLIES 5
382 Views, 5 Replies
Editing files
I cannot edit a file after the initial save.  I get the attached error.  What do I need to do?  Any help would be greatly appreciated.
Brent
5 REPLIES 5
martti.halminen
You might start by moving this thread to an Inventor forum, you'll probably find better answers there.
SBix26
Short answer: Content Center files are not editable.
Long answer: Inventor will not allow editing of files in a folder that is currently defined as Content Center files.  The CC files location is specified by Application Options > File > Default Content Center files, but can be overridden by the active project (Folder Options > Content Center Files).  If files are moved to a different folder not defined as CC files, they are editable.  If the active project is changed to define a different location for CC files, the files in the original location are editable.
Does that help?
Sam B
Inventor Professional 2015 SP1 Update 1
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
in reply to: SBix26
Yes!  Thank you so much!  I created a working folder outside of the CC location.  I'll use the CC location for released files.  If I may, I would like to ask another question.  I wanted to try to explore the Vault as a location for documentation storage/control.  I'm a single user running Inventor on a single computer.  When I try to log-in to the Vault with the default log-in information (screenshot attached), I get the attached error.  Again, any information you could provide would be appreciated.  Thanks in advance.  Brent
SBix26
We don't use Vault, so I can't help you with that.  Someone else will have to jump in.  If nobody does, I'd suggest starting a new thread with a good descriptive subject line.  You might also try the Vault forum.
Sam B
mpatchus
Have you installed and configured ADMS on your machine?
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
