Editing Extrude feature not working
It's like inventor 2018 is not working properly because if I will edit the extrude feature i cannot deselect the current profile selected or is this a bug Thanks?
Replies (15)
JDMather
Are you holding Ctrl or Shift?
Thomas_Savage
If you hold Ctrl and select the profile then it will deselect that profile.
If you go to edit the Extrusion, after creating the Extrusion, make sure you click profile to activate it, then press Ctrl, and select profile.
Then it will deselect the profile.
Hope this helps?
Thomas,
Thomas Savage
Design Engineer
Hi Thanks No im not holding the shift or ctrl
Thanks I didin't know that but there are others issues that facing like this one: the horizontal and vertical relations was interchange so if i will use a vertical relation it will make the line horizontal and the horizontal relation will make the line vertical
Thomas_Savage
That will depend on the position of your view cube.
If you rotate your view cube so that Front writing is horizontal, the the horizontal constraint will be horizontal.
If you rotate the view cube once around, then the horizontal constraint will be vertical.
Like in the print screens below.
Thomas.
Thomas Savage
Design Engineer
JDMather
@Anonymous wrote:
...the horizontal and vertical relations was interchange ...
No, you are working in 3D world now.
Horizontal is related to the XYZ Cartesian coordinate system.
If you are on an XY sketch plane then X is Horizontal and Y is vertical (no matter how you rotate the view).
If you are on any other sketch plane (XZ or YZ ) then Z is the vertical and X or Y is the horizontal.
By following this convention - the sketch constraints are always consistent no matter how you rotate the view.
If you have the sketch Axis displayed - the thick axis is Horizontal and the thin axis is Vertical.  (no matter how you rotate the view)
Hi thanks yes i can understand you sir, if i will sketch in XY Plane the vertical and horizontal is correct but if i will sketch in the YZ Plane the relationship is interchange,
This is another one IF i will select the profile the circle is also selected, which is i donot want thankss
Hi Thanks that explain when i sketch in the XZ and XY the relationship is reverse thanks.
JDMather
Do not use the View Cube as reference.
The View Cube can be changed - so it does not serve as a datum.
Use the Coordinate System glyph.
Dincbey
Could you please tell me why you need the line (at the middle) which across circles ?
JDMather
@Anonymous wrote:
This is another one IF i will select the profile the circle is also selected, which is i do not want thanks
Can you trim your sketch
or
add sketch points at intersections to define your contours
or
attach your *.ipt file here?
Im using it as a reference because i will create the top parts as a separate parts then use save as to create the lower part as separate part also, Hmmm it's like a common line for editing two mating parts, I can use top down design but it causes error sometimes so i often use it thanks,
Wow Thanks Sir by just adding sketch point it solve the puzzle.
Why does this kind of staff is not being teach in online course I feel i wasted a the 800 US dollars i paid by enrolling in an online course of inventorSmiley Sad
JDMather
Finish the design and then attach it here and I will show you the most efficient technique.
Have you gone through these
https://forums.autodesk.com/t5/inventor-forum/skillsusa-document-now-on-screencast/m-p/5856691/highl...
Aww i didn't know this one thank you for linking your tips and trick and currently i'm watching it.
