Editing Dimensions Moves The Object Across the Screen
So,
I am making 6 oblongs (12 oblong heads) within a circle, both at the same center. The oblongs are 7.08mm high and 0.82mm wide. The circle's diameter is 5.58mm, and there is an additional circle outside of this with a diameter of 20mm, also centered at the same point as the oblong and the smaller circle.
What I tried to do was to make a gap between the first 3 oblong heads of 0.82mm. This worked fine, but when I tried to make a gap between the opposing oblong-heads of 0.82mm it flung the object(s) across the plane to a new point.
I managed to move the oblongs partially back to the circle, but now, whenever I try to move them close to the circle my computer lags and I get an error message (please see picture below). Regardless of direction, my computer lags.
I used Autodesk Professional Inventor 2020.
See the pictures for more information:
Thank you for your time 🙂
