Editing Diameter of Rotor
Message 1 of 8
Dear all,
I am having some issues while trying to change my rotor diameter from 488mm to 300mm. I've converted the file from SolidWorks to Inventor 2017 and I don't know if there is any problem with that.
Do you have any sollution or advice for this case?
Thank you all,
Ricardo Andrade
Replies (7)
Message 2 of 8
JDMather
It appears that you are attempting to edit a Driven dimension on projected geometry.
This doesn't work in Inventor or in SolidWorks.
Add a new circle with center at the center of  your projected circle and dimension with a Driving dimension.
or
Attach your *.ipt file here and end all doubt.
Message 3 of 8
Dear JDMather,
the .ipt file is this one.
Thank you very much,
Ricardo Andrade
Message 4 of 8
WHolzwarth
Cutting off the existing geometry perhaps makes not much sense.
Alternatively you can derive your imported solid into a new part and scale it down. There's a scaling option in the Derive menu
Walter Holzwarth
Message 5 of 8
Dear Walter,
I've tried to do that but it appears an error, that is the following.
Thank you,
Ricardo Andrade
Message 6 of 8
TheCADWhisperer
You have to Derive into a new part file.
I think there might also be a Scale in the 2017 Direct Edit as well, but I don't have Inventor open at the moment to check.
Message 7 of 8
I'm trying to do so, but it does not change at all the diameter's dimension.
Message 8 of 8
I've found the Solution!
3D Model -> Direct -> X Scale Factor.
Thank you all!
Ricardo
