Edit with frame generator
joeldavide
Message 1 of 10
joeldavide
Hello dear community,
So, i have run with a problem with frame generator.
It only happens with IPN profiles, IPE profiles and H-profiles are fine.
Every time i want to edit one frame member it updates everything except the part Designation, which leads to the parts list not be correct.
I have also copied the IPN profile from DIN Content Center to our Custom Content Center just to be sure it was not our CC fault.
In attached i send a screen cast with this issue.
Best Regards,
Joel
Replies (9)
Message 2 of 10
CGBenner
@joeldavide
Hi Joel.  Can you share a screenshot of the Family Table for the IPN family, with the Description column visible?  And also, one more showing the Column Properties for the Description column?  Thanks in advance.
Chris Benner
Message 3 of 10
joeldavide
Hello @CGBenner ,
There you go.
Thanks for the quick reply.
Message 4 of 10
joeldavide
So... no clue?
Message 5 of 10
blandb
Do you get the same thing if you place it as custom?
Autodesk Certified Professional
Message 6 of 10
joeldavide
If i place it as custom everything is fine.
It only happens with frame generator.
Message 7 of 10
CGBenner
@joeldavide
I have been trying to get the same result on my test files, but cannot reproduce this.  Is there any chance that you could share a small example assembly (use pack and go and make sure that "Skip Libraries" is unchecked), so I can try it out with your files?  Maybe one of us can find a clue.
Chris Benner
Message 8 of 10
joeldavide
Hello @CGBenner ,
here you have a simple assembly with the profiles:
https://we.tl/t-TF7uBpHGsm
Best Regards,
Joel
Message 9 of 10
CGBenner
@joeldavide
Are you able to attach the zip file here in the forum?
Chris Benner
Message 10 of 10
joeldavide
Yes of course.
