Edit the structure of the assembly tree
colin.ngNB7PC
colin.ngNB7PC
Hi there,
I've been working with Inventor since March this year and I'm now realising that I always make the same mistake when working with assemblies that contain subassemblies.
I'll add parts into the assembly and constrain them accordingly, and only much later realise that those part files should have been part of a subassembly, instead of being a direct child of the main assembly. Would it be possible to easily swap it over to be part of the subassembly that I need it to be under?
So far I've been deleting the part files then adding them back in to the subassemblies that they should be under, so a faster way to do it would be better. Of course, I'm also working on being more careful and adding them to the correct subassembly so I can prevent any rework!
gcoombridge
You can just drag the part in the browser onto the subassembly node. Warning though, any constraints between parts that are not in the subassembly will be lost.
Alternatively right click on the part/parts and choose demote... This will create a new subassembly.
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
JDMather
Although Inventor automatically generates this warning, I almost never in fact lose ANY assembly constraints.  I think with logical assembly constraints - Inventor nearly always sorts them out.
swalton
I sometimes use the Demote command to move components in the top-level assembly to a new sub-assembly.
Steve Walton
Inventor 2025
Vault Professional 2025
colin.ngNB7PC
Thank you so much! I tried dragging before but didn't think to expand the feature tree of the target subassembly. Worked like a charm and all constraints were maintained too.
