I've replaced some reference geometry on a drawing with a 3D sketch which is like a wire frame (include geometry option).
I'd like this to appear as a dashed or dotted line on the drawing but searching for options - any ideas?
Regards
Andrew
Solved by johnsonshiue. Go to Solution.
Solved by kacper.suchomski. Go to Solution.
Hi
Right-click -> Properties?
Kacper Suchomski
Hi Andrew,
By default, the 3D sketch from the model is placed on 3D Sketch Geometry layer. Go to Styles Editor -> Layers -> 3D Sketch Geometry -> change the linetype.
Many thanks!
Found an issue with the Object Defaults assigning a different layer for 3d sketches.
