I have started to use tube and pipe in Inventor professional.
I have a couple of questions currently.
Q1: Edit route
How can I delete some of the items in the current route.
The RMB does not have an option to do so!
Q2:Q2: Butterfly valves
I need to use butterfly valves. I could not find: where can I find butterfly valves in content center?
Welcome to the world of Tube & Pipe!
I'll answer the easy question first. Content Center has only a very small library of very generic valves, because valve manufacturers and sizes vary so greatly. In my ten years of using tube & pipe, I either modeled or downloaded and then published all of my own valve libraries. That way I knew they would fir in the lined based on the manufacturers dimensions. Depending on whose valves you use, some are available for download (maybe check with your suppliers for step files), but some may need to be modeled from scratch. You will then need to Author them and Publish to your own Read/Write library in the Content Center.
As to the deleting question... in your image it appears that you are trying to delete both pipes and fittings from your route? May I ask why (it might help me advise you). First, I don't think you can delete both at the same time from the browser. And second, if you delete a pipe segment from the browser, it deletes the sketch line from your route as well, and any fittings sitting on the segment. The node where the fitting is sitting will be deleted and the line will now terminate at the next logical sketch point or intersection.
If you share with us what is going on, I can probably offer some advice on how to get there. Also, take a look at the following resources, from before I joined Autodesk when I was using tube & pipe every day.
My first (beginners) Tube & Pipe class from Autodesk University
Last year's Tube & Pipe demo class
Authoring & Publishing Custom Content
Hopefully these can offer you some good starting tips, tube & pipe has a steep learning curve.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Thanks CGBenner.
I agree with you. There are so many valves and CC can't have all of them. That's fine. I am comfortable in creating library items.
I am new in using Tube-and-Pipe. May be my questions are vague (not line up with the proper use of it).
I need to learn more.
My current issue is I need basically to edit the dis-jointed route shown below. Need to detail as separate spools. I can delete the whole route, in that case I will have to create new routes.
