EDIT OR DELETE HATCH IN A SKETCH
Message 1 of 13
I am using Inventor Pro 2019 and am unable to edit or delete the hatch pattern in a .dwg sketch. I would like to delete the hatch pattern without deleting the sketch and at other times I would like to be able to edit the hatch properties, such as angle, scale or hatch pattern type. I have tried solutions posted by other users, but the functionality to do this seems to have disappeared since earlier versions.
Anyone able to help?
Replies (12)
Message 2 of 13
Xun.Zhang
Howdy @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Edit the hatch and then select None in the dropdown list.
Hope it helps!
Xun
Message 3 of 13
johnsonshiue
Hi! Please take a look at Xun's reply. If it does not work for you, please share an example here. There should be a logical reason to explain the behavior.
Many thanks!
Software Test Engineer
Message 4 of 13
Thanks Xun. I have inserted a screen cast of me using your solution.
Message 5 of 13
Message 6 of 13
bene.mr.lol
Observer
Observer
I have this issues except the option "none" does not exist 😞
Message 7 of 13
johnsonshiue
Hi! If possible, please share the drawing file here. I would like to understand the hatching behavior better.
Many thanks!
Message 8 of 13
jenningsj8X9VK
Observer
Observer
This a real flaw in the software. It should be as simple as highlighting the hatch pattern and then hitting the Delete button on my keyboard.
My system doesn't even show an option for None.
Message 9 of 13
SBix26
I agree that it's not as intuitive as it ought to be, but it works on my system.  What version of Inventor are you using, and what updates have you applied to it?
Sam B
Inventor Pro 2024.1 | Windows 10 Home 22H2
Message 10 of 13
FINET_Laurent
Did you find a solution ?
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 11 of 13
RogerdeSmidt
Sorry, please ignore this comment.
Message 12 of 13
carlX5992
Community Visitor
Community Visitor
no such button to edit hatch
Message 13 of 13
ole_hoffmannHW73Z
Community Visitor
Community Visitor
If you delete one of the lines that form the border for the hatch, the hatch itself also disappears. To re-add the hatch just project or draw the line again and add a new hatch pattern to the area
