Edit dimension when created not working
LeeJohnson3530
Message 1 of 14
LeeJohnson3530
a few months ago, possibly when installing the Inventor 2016 my edit dimension when created option stopped working, I have checked under options and the box is checked however the dimension is created i then have to edit that separately as another step. is there a solution to get it working again?
Replies (13)
Message 2 of 14
Mark.Lancaster
So when you start a dimension, right mouse click and in the context menu, edit dimension is checked?   What option are you referring to in Application Options when you say edit dimension is checked, is that under the drawing tab?  If so, that's for when you are creating dimensions in drawings.
Mark Lancaster
Message 3 of 14
JDMather
@LeeJohnson3530 wrote:
.... I have checked under options and the box is checked ...
Post screen shots - both of the Application Options and the right click in-context menu.
Have you installed Service Pack 1?
Message 4 of 14
LeeJohnson3530
So when you start a dimension, right mouse click and in the context menu, edit dimension is checked? (this is correct when I am in the sketch environment) I have looked under Application Options / Sketch Tab / Constraint Settings/ General Tab and under "Dimension" the Edit dimensions when Created box is checked however when I create a dimension it needs to be clicked once to place the dimension text then a second time to edit it. Previously the edit box appeared when I clicked to placed the dimension. (first click). What option are you referring to in Application Options when you say edit dimension is checked, is that under the drawing tab? (Yes this is also correct) If so, that's for when you are creating dimensions in text. (ok thank you in understand the difference this is not related to the above problem) _____ No virus found in this message. Checked by AVG - www.avg.com Version: 2016.0.7227 / Virus Database: 4460/11025 - Release Date: 11/18/15
Message 5 of 14
Mark.Lancaster
Ok..  Wnat about JD's question about service pack 1?  Have your applied that yet?
Mark Lancaster
Message 6 of 14
LeeJohnson3530
I don't know for sure but i can do that to see if it resolves the issue.
Message 7 of 14
mdavis22569
https://knowledge.autodesk.com/support/inventor-products/downloads?release=2016
make sure you install them all   as @JDMather mentioned
Mike Davis
Message 8 of 14
SBix26
Service Packs typically include all previous Updates, Hotfixes & Service Packs, so no need to "install them all"-- just install SP1.
Sam B
Inventor Professional 2016 R2 SP1
Vault Basic 2016
Windows 7 Enterprise 64-bit, SP1
Message 9 of 14
LeeJohnson3530
yes it is currently checked, for some reason i am getting the edit dimension option upon placement of the dimension as i was used to. so i am not sure what the solution was. i had the same problem a few months back and it came and went. i did not intentionally change any settings. it may be possible that i did unintentionally. is that the best place (right click during dimension creation) to activate the option?
thanks,
Lee
Message 10 of 14
johnsonshiue
Hi! The behavior is controlled in two access points: Edit Dimension dialog and Application Options -> Drawing. When you make change in one, the other should follow. When "Edit dimension when created" option is off in Edit Dimension dialog, the same option in Application Options -> Drawing should be off, vice versa.
Could you check and see if the options are in sync?
Thanks!
Software Test Engineer
Message 11 of 14
I would like to edit dimensions when I create them.  I am using Inventor 2016 SP 1.  There used to be a box to check for this in Application Options under the Sketch tab.  I am enclosing two screenshots.  One of my current Application Options and one from a tip by David Gaskins in Cadalyst magazine showing an earlier version of the same screen in an earlier version with a red arrow highlighting the box I would really like to have access to again.  Is there any way I can gain this functionality again?  Is there a reason this was removed?  I am curious as to why it is no longer there.  Has it been moved?  If so to where?  Thanks!
Message 12 of 14
johnsonshiue
Hi! In the same dialog, click on "Settings" button at the top under Constraint Settings. You will see "Edit dimension when created" checkbox there.
Thanks!
Message 13 of 14
That did it. Thank you!
Message 14 of 14
Christopher2222
This is exactly my issue.  The edit dimension when created is not working for some reason, it didn't work yesterday.  Started today and it was working, then later this afternoon not working again.  I have the edit dimension checked and the edit dimension when created checked.  Gotta be something I'm not doing and I can't figure it out.
