Edit Dimension Stack in Inventor can not
ywlee4QQKV
ywlee4QQKV
The dimensional stack doesn't work, and when I edit and open the changed stack in the previous drawing, it appears as strange text.
If +0.039^0 is converted into a stack
+0.039
 0
It should be expressed like this.
However, if you encounter a problem, the stack button is unresponsive, and when you check the data in the stack edit of a previously completed drawing, the following text appears.
\S<2/70>+0.039^0\s
The product you are using is Inventor Professional 2025 and even the latest hotfix update has been applied. It is the same after restarting, resetting, and reinstalling the product.
Windows operating system is Windows pro 11.
Please check the attached video file.
ywlee4QQKV
This phenomenon is an error phenomenon that applies to all templates, including iso.idw, which is not a specific template, but iso.idw, which is native to Autodesk.
kacper.suchomski
Hi
You can also create a tolerance description using dedicated tools in the middle tab of the dimension dialog box.
Kacper Suchomski
ywlee4QQKV
Correct, but with a dedicated tool, parentheses are automatically entered into the tolerance. I have to fill in the tolerance without parentheses to express it the same as the drawing in Autocad.
kacper.suchomski
It works for me (2026.1).
Are you sure you have all updates installed?
Kacper Suchomski
ywlee4QQKV
I use that version. 2025.3.1
In the 2026 version of inventer professional, this stack problem does not occur. In the 2026 version, it works well on my pc like the video you shared.
However, I have to use 2025 version due to compatibility issue of ipt file.
ywlee4QQKV
