Edit Dimension Stack in Inventor can not
- Mute
- Permalink
- Report
The dimensional stack doesn't work, and when I edit and open the changed stack in the previous drawing, it appears as strange text.
If +0.039^0 is converted into a stack
+0.039
0
It should be expressed like this.
However, if you encounter a problem, the stack button is unresponsive, and when you check the data in the stack edit of a previously completed drawing, the following text appears.
\S<2/70>+0.039^0\s
The product you are using is Inventor Professional 2025 and even the latest hotfix update has been applied. It is the same after restarting, resetting, and reinstalling the product.
Windows operating system is Windows pro 11.
Please check the attached video file.
