Edit Dimension Line Break
I have seen several posts concerning adding breaks to dimension lines, such as by adding a break to the view, but my issue is slightly different.
I have a dimension in cramped quarters where the text from a leader text call out overlays the dimension line.  Inventor automatically crops (or masks) the dimension line under the text, but does not leave any gap; so the dimension line still touches the text.
I would like to edit the gap (or change settings) so that there is a small space between the cropped ends of the dimension line and the text.
Replies (8)
johnsonshiue
Hi! Several things can lead to the behavior. Do you mind sharing an example here so forum experts can take a look?
Many thanks!
Software Test Engineer
Cadmanto
The only setting I know of is in the styles manager.
If you are talking about something else, could post some pics of what exactly you are talking about?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Sorry for the delay in replying.  I tried to attach a simple drawing the other day, but it didn't seem to accept my post.  Still not working.
I did see that C: gap setting in the style editor, but that setting doesn't seem to be applied to what I am referring to.
To duplicate the situation, bring any simple part into a drawing base view; snap a dimension in the vertical axis; add a leader text with any text to the part (i.e. type 'TEXT'); then drag the text location so that it sits over/on top of the dimension line.  You will be able to place the text such that the dimension lines touch the top and bottom of one of the letters in the text.
Not sure if it is me or the board that is having a problem accepting attachments; I see there is a history there.
Cadmanto
I tried what I think you re describing shown below.  I got a break in the dimension.
DIM BREAK.png+
Inventor Pro 2018
Best Regards,
Scott McFadden
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous here is an older thread that shows a similar workaround that could be useful using Sketch Symbol to mask the line.
BREAK CENTERLINE WHEN IT GOES THROUGH A DIMENSION
Inventor Trim Reference Overlapping Dimension Lines To Appear Cut
Please select the Accept as Solution button if a post solves your issue or answers your question.
Yes, this is what I'm talking about, and if you have the option of placing the text to where a natural spacing between the letters of the text land where the dimension line crosses, it doesn't look bad; but if a letter of text is smack on the line there is no gap and the dimension line touches.
Hmm, this goes to a link with another link that shows more or less what the outcome should be, but I must be missing where it actually shows or explains how to achieve the "solution".  Sure you can probably make a sketch to mask over the dim line, but that seems like it will create later confusion and issues, not being the best solution.
Regardless, I reworked my drawing to avoid the problem, so for the moment this is now just a thoughtful exercise.
Thanks.
kelly.young
Autodesk Support
Autodesk Support
@Anonymous yeah there are a few different links in those posts.
Here is a short screencast showing how to use Define Sketch Symbol to clip the line and stick to the Leader.
Please select the Accept Solution button if a post solves your issue or answers your question.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
