Inventor Forum
edit adsk file - for import to Revit
4 REPLIES 4
Karol_Piroska
533 Views, 4 Replies
Hi, I have no idea if this is possible but can you edit adsk file in Inventor? I have an adsk file that needs to be imported into Revit, but unfortunately Revit doesnt like its size (limitation is 128MB, the file is 127MB). I wonder if it is possible to edit the file and remove some geometry to make it few MB smaller.
4 REPLIES 4
thanks @Chancellor.Kurre . I have some adsk files from a supplier to add into my Revit model for coordination purposes but they all fail to open in inventor. I can add most of them to Revit, but none of the larger ones (even though they are just close to the 128MB Revit limit).
I'd start down the Revit end and see if there's a reason 127 mb won't open. I don't spend much time in Revit so I don't know specifics of the file size limitations, but if the limit is 128 then it should open 127
Hi Folks,
Unfortunately, Inventor can only export .adsk file but not import or edit.
Many thanks!
Software Test Engineer
Technology Administrators
