Inventor Forum
Edges in shaded views?
8 REPLIES 8
Message 1 of 9
612 Views, 8 Replies
In INV 5.3 IDWs. Couldn't you control the display of edges of shaded views?
I thought there was a check box for it. Was this option removed in INV 6?
Wayne
8 REPLIES 8
Message 2 of 9
Wayne,
You can turn this off from Tools->Application options->Display tab. Uncheck
the Edge display under "Active" for shaded display.
-Sanjay.
"W Massey" wrote in message
news:B5CCC2E0049F6F0D5638C17873E59D27@in.WebX.maYIadrTaRb...
views?
> Thanks,
> Wayne
Message 3 of 9
Unchecking the Edge display under Active for Shaded Display does not remove
the heavy Cartoon lines in my shaded views. Are there some combination of
settings that will work, or is it wait for SP2?
Ed R
"Sanjay Jayabal" wrote in message
news:D7A99B71B5C959D4B1313D1561525A6B@in.WebX.maYIadrTaRb...
> Wayne,
Uncheck
> -Sanjay.
> views?
6?
> > Thanks,
> > Wayne
Message 4 of 9
If you RMB>Edit View, there is an Options tab which has an option to uncheck
tangent edges, but it's always grayed out if I'm making the view shaded -
anyone else seeing this?
"Ed Rasmussen" wrote in message
news:B2F0B435E535384D71BB6D16B5B9FF25@in.WebX.maYIadrTaRb...
remove
> Ed R
> > Wayne,
> Uncheck
> > -Sanjay.
> > views?
> 6?
> > > Thanks,
> > > Wayne
Message 5 of 9
It is grayed out on mine as well, not only for editing the view, but also
when placing a new shaded view.
Ed R
"Alan Rennick" wrote in message
news:0D2C5E4FDED36B8F7597B22E79DEA60D@in.WebX.maYIadrTaRb...
uncheck
> remove
of
> > Ed R
> > > Wayne,
> > Uncheck
> > > -Sanjay.
> > > views?
INV
> > 6?
> > > > Thanks,
> > > > Wayne
Message 6 of 9
Hi Ed,
Can you give me a data set that shows these cartoon lines? Thanks!
-Sanjay Jayabal
remove
> Ed R
> > Wayne,
> Uncheck
> > -Sanjay.
> > views?
> 6?
> > > Thanks,
> > > Wayne
Message 7 of 9
I proposed this as a bug right before SP1 came out. Not sure what became of
it.
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
news:0928B2641F6397B7BF08A940D860D2D9@in.WebX.maYIadrTaRb...
> Ed R
> uncheck
shaded -
> > remove
combination
> of
> > > Ed R
> > > > Wayne,
> > > Uncheck
> > > > -Sanjay.
shaded
> > > > views?
> INV
> > > 6?
> > > > > Thanks,
> > > > > Wayne
Message 8 of 9
Sanjay,
I just emailed you an example of one of the drawing files that shows the
problem. Thanks for your interest.
Ed R
news:30B8BEF731234CE9D4C2DD4641F8170E@in.WebX.maYIadrTaRb...
> Hi Ed,
> -Sanjay Jayabal
> remove
of
> > Ed R
> > > Wayne,
> > Uncheck
> > > -Sanjay.
> > > views?
INV
> > 6?
> > > > Thanks,
> > > > Wayne
Message 9 of 9
Urg, I suppose it's time to re-propose it, then!
Maybe it will be addressed with the problem Ed's seeing too?
"Sean Dotson" wrote in message
news:516E415576A4E6D6AEEC9D4C40A34D10@in.WebX.maYIadrTaRb...
of
> it.
> Sean Dotson, PE
