Dynamic Simulation - Redundant joints and other questions
karthur1
Mentor Mentor
Message 1 of 12
karthur1
Trying to get a simulation to work with my mechanism.    Can't make any progress clearing them.  I have the "Automatically Convert Constrains to Standard Joints" checked. I have built most of the assembly using joints rather than constraints. It works great when I move it in the assembly environment, but when I go to Dyn Sim, I get these redundant joints.
Another question is why is this one item in my browser shown in BOLD?  Even when I go back to the assembly environment, it is still bold.
I don't do these dyn Sim very often, so any tips are appreciated.
Replies (11)
Message 2 of 12
j.palmeL29YX
Without seeing your model it is almost impossible to give helpful answers. Post your files (.iam, .ipt) please. And tell us which Inventor version you use.
BTW: The Help (F1) says: Bold letters identify parts linked to selected objects.
Jürgen Palme
Message 3 of 12
karthur1
There is nothing selected and its still bold.  Let me get the files together.
Message 4 of 12
karthur1
@j.palmeL29YX
See Attached for the files.  See the F3635-D828_V2 Dyn Simulation.iam file. My files were done in Inv 2020.
Message 5 of 12
JDMather
I have only just started looking at the assembly - but you should not have spring parts in the Dynamic Simulation.  Instead use Spring Joints.
Minor point - I found an interference here...
Message 6 of 12
karthur1
There is a "Stress Analysis" LOD that suppresses those springs.
I found another example where you helped someone else that was having redundant issues as well.  I am just starting to look at the way you got it to work, but I think the solution to my issue might be similar.
Message 7 of 12
karthur1
@JDMather
I got the joints so there are no more redundancies, but when I try to drag, I get "Impossible to proceed with the simulation.  Check the input data."
I attached the iam below.  It uses the same parts as my previous iam.
Message 8 of 12
j.palmeL29YX
First I checked your first posted assembly (<<Click<<).
A lot of interferences (see attached image), a lot of redundancies - but the simulation >>works well<<
Then I found your second upload (>>Click<<). Still some interferences, also o redundant joint - but the simulation >>works well too<<
I do not yet see how I could help you.
Only some tips (my opinion):
- First remove all modelling errors (interferences)
- Then I'd add each joint (in the DS) manually step by step. Check each joint step by step if it works as you expect.
- At least one joint should be a "driving" joint (or do you really want the gravity as driving force?).
I do not know what you expect how the mechanism should work (at the moment it moves in a not realistic manner). If you can explain what's your goal I can perhaps give you more help.
For a rough test I added a spring and also two vertical forces - see the >>simulation<< result. Obviously it works well.
Jürgen Palme
Message 9 of 12
j.palmeL29YX
Here still another test: I open your (second posted) assembly.  I do not change anything on the assembly. Go to Dyn. Simulation and can drag the mechanism >>without of problems<<. I can't reproduce what you're reclaiming about.
Jürgen Palme
Message 10 of 12
JDMather
You have wayyyy too many top-level assembly constraints.  Demote components into sub-assemblies that move together.  This will dramatically reduce the number of DS Joints.
I started to do this to illustrate and then as @j.palmeL29YX pointed out - I got to thinking, "What is your intent?"
If you are going to run Motion Loads Analysis (FEA) on any of the parts - I need to leave those parts at the top level rather than demoting to one of the sub-assemblies.
Please advise before I continue work.
Message 11 of 12
karthur1
@JDMather
Can I send you a private email?
Message 12 of 12
TheCADWhisperer
TheCADWhisperatgmaildotcom
