Dynamic simulation = > restitution
Message 1 of 21
Hi!
I am learning Dynamic simulation = > restitution.
I use the tutorial by @JDMather
https://www.youtube.com/watch?v=Rer-IjWzKAU&list=PLp5izJt_zvN08mpY4UcYrzJV2N6QOLAIR&index=6
I have trouble in creating 2d contact
The assembly is attached
Thank you.
Replies (20)
Message 2 of 21
JDMather
Think Fences!
Uhmm, Sketch1 of your Ball is not fully defined?
Have you gone through these Tutorials?
Sketch1 of restitution platform is not fully defined??
Sketch2 of restitution platform is not fully defined???
Message 3 of 21
Hi
My questions are coming because I'm going through your tutorials right now
Message 4 of 21
This is the exercise from your ---restitution  tutorial
Message 5 of 21
I have set the constrains.
Think Fences!
I didn't understand the hint)))
Message 6 of 21
JDMather
@Anonymous wrote:
Hi
In all of my tutorials the sketches are fully defined.
We better go back to the very beginning.
Attach you Revolution Joint files here.
Message 7 of 21
Great!
Thank you!
I will post them on Monday
Message 8 of 21
Hi!
I have attached the revol. joint files.
They are not the same as yours since I have done this from memory.
I almost  didn't have problems with that.
As I mentioned before I don't understand the concept of arrows and how to use them properly.
Thanks!
Message 9 of 21
JDMather
You did fully define the sketches on the parts for the Revolution Joint.
Not sure why you didn't fully define the sketches for this ball-drop problem?
Underdefined sketches should keep you awake at night.
You should not be able to eat or sleep.
Message 10 of 21
JDMather
For 2D Contact Joint you need to think in my term as "Fences" that extend to infinity.
The fence profiles must be co-planar or on parallel planes.
For illustration purposes I added a "keep-in fence to your ball drop problem.
Then I turned it sideways to illustrate next to the previous Planar Joint problem.
Note that the two problems are essentially identical when viewed as "Fences".
The only thing that has changed is the orientation of the fences.
Message 11 of 21
Well, I fully constrained the sketches   I have and thought that it is enough.
I'll try to implement the "fences approach and will let you know.
 Thanks!
Message 12 of 21
Yes, it works!
Thank you!
But arrows are still the mystery for me.
In this example there are 4 combinations for arrows positioning.
I have tried all of them and the  last one works fine.
I am not sure that it is a smart approach))
Could you please explain me)))
Message 13 of 21
JDMather
Could you please explain me?
No files Attached?
Message 14 of 21
Here it comes
and here are the images:
Message 15 of 21
JDMather
Z is incorrect in both of those images.
Z should point to the outside.
The outside of your ball would be with Z pointing out.
Since you want to keep the ball outside of the "fence" the Z should be pointing out of the "fence".
(If you wanted the ball to stay inside of a "fence" the Z would be pointing inside the fence.  X and Y directions don't matter in this case.)
Message 16 of 21
There are 4 different images
Message 17 of 21
JDMather
I didn't see the 4th image - it is correct in that image.
The mark of a good student in the classroom who has gained understanding - would have told me that I must have missed the 4th image.
When you know you are right - you know you are right.
Message 18 of 21
ok.
I have got the idea about the base,
but I still have a question regrading the ball's axis.
If I place arrow towards down it is outside of the ball
If I place arrow towards up it is still  outside of the ball
There is not Z axis which directed inside of the ball.
Is this an issue of a terminology?
Message 19 of 21
JDMather
I think that you are getting confused by the length of the arrow (depends on zoom level).
Look at the origin of the triad.  The direction is...
Message 20 of 21
ok. I got it.
