I've seen several versions of this question on the forums, but never a full answer. I'm trying to model a catenary (or sagging) cable / rope in dynamic simulation. It wraps around a pulley at it's highest point, and it's attached to a weight at the bottom, which is simultaneously attached to another cable on a trolley system. The picture below shows the setup.
I have it working treating the cables as rigid rods, but it's clear that the cable on the right will experience some sag. I have a few ideas on how to approach this.
- Segment the cables into a hundred smaller cables and link them all together
- Use the catenary equation and adaptivity to have the curve change as it moves (does adaptivity work with dynamic simulation?)
- Use a sort of spring / damper if it has the ability to sag (least fleshed out idea)
If anyone has another idea how to approach this, or can back up / eliminate one of the ideas above, it would be greatly appreciated.
