Dynamic Simulation, arbor press  example
 Hi!
I am following the tutorial by @JDMather
The subject is Dynamic Simulation, arbor press  example
I have downloaded files from https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/downloads/content/inventor-2015...
The reason for downloading from this source is because this is the only link for downloadable files I have seen in this tutorials
There is difference between  constrains in downloadable files and constrains in the web tutorial.
Here is the image of  constrains in web tutorial
And here is the image of constrains in the downloaded files
Arbor Press in files.PNGx
Where do  I get the right files?
Thanks.
JDMather
That is simply a Mate with Limits.
Resting Position 2" from table.
I recommend deleting all of the assembly constraints and then putting in your own - that way you have a full understanding of the assembly.  You develop supreme confidence in your techniques.
thank you!
