Hi @KubliJ,
Very happy when I received your explanation, and knew that my first set up is correct. However, let me ask you that
1. If I use 2D sketch like that, do I can get the same value with using 3D model? Because, if the answer is yes, so I can use 2D sketch for decrease time consuming and can get reasonable results.
2. As you can see, in order to close this door under the external force 30 kN and self-weight, this cylinder's force is more than 244 kN (driving force) -> it means that with 75kN, this cylinder cannot drive the door under this external force --> this statement is correct or not?
and these reaction forces at each point (A, B, D and O) are shown in this picture as well.
However, in fact, this door is operated by cylinder with its force is only 75kN. If I apply 75kN in joint force (and ofcourse disable imposed motion)
so at this case, do I need to set up angle between door blade from 180 degree to 0 degree? If not, this door is moved very fast and it seems uncontrol, so I have to set the operation angle for the door blade
I got the results (I don't set up operation angle of the door blade, just set the value of cylinder force 75kN)
so now, I can get new reaction forces caused by the effect of 75kN cylinder force.
It is a bit confusing, because, at the first step, this cylinder force is at least 244kN to close the door, but now, with 75kN this cylinder still operate this door? How to make this point more clear?
Please take a look and help me to solve this problem
Thanks in advance for your kind help
