DWG Underlay issue
DWG Underlay issue
alex_xuCAU9F
DWG Underlay issue
alex_xuCAU9F
I am having issue with DWG underlay.
In the model, the dwg underlay is hidden under the solid but in the drawing view you can see all the dwg underlay.
Is there a way to hide the lines behind the solid?
Thank you.
James_Willo
Hi, if you set the view to 'Shaded' this would colour in the 3D and hide the underlay. However I think the entire underlay might also disappear in Shaded view?
Other than that I think you would have to create a hatch pattern for the 3D in order to hide it.
James W
Inventor UX Designer
johnsonshiue
Hi! Unfortunately, it is a limitation in the drawing environment when displaying a DWG underlay. I am not aware of a solution to fix it yet.
Many thanks!
Software Test Engineer
rhasell
Hi
This might be something for future builds? The underlay is great, but not following the rules of the drawing view is very frustrating.
Reg
2026.3
johnsonshiue
Hi Reg,
I am sorry I don't have any update on this issue. I am not aware of a solution yet unfortunately.
Many thanks!
