DWG underlay is not visible
For some reason the DWG underlay no longer appears as displayed in the first screenshot. The second screenshot displays what the underlay is while the first one displays the objects that should be placed on it. It was showed up fine with the 3D objects on Friday when i was working on it.
andrewdroth
Is the sketch visibility turned off in that part? Are sketches turned off in the view tab?
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
it is turned on in the pictures
Part in assembly vs part by itself
johnsonshiue
Hi! In assembly, set the browser to Model (instead of Assembly). Right-click on the invisible DWG Underlay node -> check Visible. Does it work for you?
Many thanks!
Software Test Engineer
The browser is already set to Model
johnsonshiue
Hi! The behavior does not look right. Please share the files here. I need to take a closer look.
Many thank!
