DWG File format taking too long to save in Inventor
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I started a job recently in a company producing facade framework for construction projects, and my job is to model up a set of frames, and then place this model onto pages which can be printed and used by our factory to construct for the customer. Over the last few years, we utilized Inventor to help aid with the design phase, as a lot of our customers would use 3D models to aid construction.
We have found that placing views of models onto DWG format over IDW was more efficient, as we could easily import it into AutoCAD if we needed to. However, it was instantly obvious that it was taking too long for the DWG format to save on my computer, what should have taken a couple of seconds would take 45 minutes. My computer is the first computer in the company to run on Windows 11, and currently the only one that runs Windows 11 with Inventor.
I started out with Inventor 2022, of which the whole business was using at that point, and as of recently, we have all upgraded to Inventor 2023. The same issue occurs. I have been using IDW format in the time between when I started and now, which works just fine, however lacks some useful features which are found in DWG format.
I suspect this would be a Windows 11 incompatibility, but I am willing for any suggestions as to how to fix this issue.
