Hi Michael,
A few things to consider. You may use AutoCAD to create associative drawing views for Inventor components. The command is called VIEWBASE.
Or you may export the Inventor drawing to an AutoCAD dwg. Or you may open the Inventor dwg file in AutoCAD and use EXPORTLAYOUT to export the sheet to an AutoCAD dwg file.
Many thanks!
Software Test Engineer
