DWG Arc Lengths from a datum point
nige106
nige106
Is it possible to create something like a "Baseline Set" except around a curve. In AutoCAD I can reposition the grips, however I can't see easily how to achieve this in Inventor?
Many Thanks,
johnsonshiue
Hi! Are you trying to populate the dimension of 324mm to all other elements?
Many thanks!
Software Test Engineer
nige106
Good Morning, sorry for the vagueness. I'd like to dimension as per the below screenshot. I quickly added these in AutoCAD:
Mario.VanWiechen
I have done this but it was beyond tedious. I put a sketch on the view and drew arcs to all the points I wanted. Color them white so they do not show in the paper drawings and use arc length dimension
nige106
I did try sketching various length curves, however when dimensioning I couldn’t seem to “select other”, like normal.
Mario.VanWiechen
The arcs in the sketch should be different sizes by .005 or less, a small enough amount it does not affect the arc length enough to matter. Yes they will be hard to pick out, you will have to zoom in very close to pick them.
nige106
Thanks for your responses. Makes sense but seems like a bit of a work around. It's a pity you can't drag the attachment points like you can with any other dimensions.
