DWF output is affected by Inventor Visual Style
DSilver4773
DSilver4773
I discovered an issue recently when creating a DWF files from an Inventor Assembly that I am working on. I typically have my visual style set to Shaded with Edges however when I create a DWF with these settings I get phantom lines in my dwf. I found the only way to resolve this was to change my Visual Style settings to shaded.  Not sure if this constitutes a bug or if there is a valid explination for this error. I should also note that this issue only occurs on parts with curved segments. I have a similar assembly with straight parts and I don't see this issue.
rui_wang
@DSilver4773
Thanks for your reporting. Could you please help to share your files with us for more investigation? My email, rui.wang@autodesk.com.
-Rui
DSilver4773
Hi Rui,
I have places the files on my A360 drive and sent you an invite
rui_wang
Thanks for your information.
Ticket has been created on Inventor bug system - INVGEN-38417.
Suggestion, if you are trying to export dwf file with assembly file, please select the Complete mode in Export DWF options.
-Rui
