style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"av8r" <I
href="mailto:kevin_gill@southwire.com">kevin_gill@southwire.com> wrote
in message
href="news:f1449a6.-1@WebX.maYIadrTaRb">news:f1449a6.-1@WebX.maYIadrTaRb...
know the dual processor question has been discussed at length on tis NG. I was
just wondering if there is any special setup in IV to allow (or make) the IDW
use the second processor?
We are running Win 2000 Pro. Nobody here has any
experiance with dual processor machines. I was jsut wondering if there is any
special setup required.
I know this sounds like a stupid question. But I
have looked and can not find any information
anywhere.
Kevin
"av8r" <I
in message
anywhere.
Kevin
"Ashley Fulks" <
href="mailto:ashley@nisku.ca">ashley@nisku.ca> wrote in message
href="news:7DCBFE1CCE7D9716888F572F900F1222@in.WebX.maYIadrTaRb">news:7DCBFE1CCE7D9716888F572F900......
A handy way to get IV to make the most use out of
your second processor:
CTRL+ALT+DEL to get to task manager
List all the processes
Right Click on each process and click on
"affinity"
change the affinity to only use the first
processor on all processes
when you get to inventor.exe, change it's
affinity to the second processor
Then IV will have it's own processor to crunch
on while the OS runs on the first.
Ashley
Fulks
Production Manager @
href="http://www.nisku.ca">www.nisku.ca
Specialized Supercomputers for
Inventor
href="http://www.nisku.ca/autocomp.htm">http://www.nisku.ca/autocomp.htm
href="http://www.nisku.ca/autocomp/autocompII.html">http://www.nisku.ca/autocomp/autocompII.html
"av8r" <I
wrote in message
was just wondering if there is any special setup in IV to allow (or make)
the IDW use the second processor?
here has any experiance with dual processor machines. I was jsut wondering
if there is any special setup required.
question. But I have looked and can not find any information
anywhere.
Kevin
"Matt Stocking" <
href="mailto:matthew.stocking@verizon.net">matthew.stocking@verizon.net>
wrote in message
href="news:9BEB38C48DEED320CCE45BF42D1BAB21@in.WebX.maYIadrTaRb">news:9BEB38C48DEED320CCE45BF42D1......
no, no. dont change any affinity's
the os handles that for you. it will breakup
the load evenly between the 2 cpu's. some programs dont work well this way,
thats why there is an affinity setting.
changing everything but inventor to 1 cpu would
make you machine act like a single cpu.
Matt
"Hal Gwin" <
href="mailto:hal.gwinNS@xenogen.com">hal.gwinNS@xenogen.com> wrote in
message
href="news:916C2893C79AD6A66AB679C93D2F275F@in.WebX.maYIadrTaRb">news:916C2893C79AD6A66AB679C93D2......
Actually it works quite well. IV has been
more stable running on its own processor. I can count the number of
crashes I have had in IV since I got my new machine (about 4 weeks ago) on one
hand with enough fingers left over to hold a cup of coffee. When ever I
work on IDWs I switch IV back to both processors. All my other apps run
on the other processor, however the OS will not let you change the affinity
for some of the services that are running.
size=2>
Hal Gwin
Mechanical Designer
Xenogen
Dell 650
Dual 2.66GHz
Xeon
1.5GB DDR RAM
Quadro4 900XGL
nVidia 6.13.10.4072
Drivers
"Matt Stocking" <
wrote in message
href="news:9BEB38C48DEED320CCE45BF42D1BAB21@in.WebX.maYIadrTaRb">news:9BEB38C48DEED320CCE45BF42......
breakup the load evenly between the 2 cpu's. some programs dont work well
this way, thats why there is an affinity setting.
size=2>Matt
"gcooper" <
href="mailto:greggc@svitrucks.com">greggc@svitrucks.com> wrote in
message
href="news:7EDA972DE41D2E7060970C41D768D4B9@in.WebX.maYIadrTaRb">news:7EDA972DE41D2E7060970C41D76......
Not to stray from the topic, but. Why are there
up to 31 processors showing (but grayed out) when setting afinity? I thought
NT could only support two? Any body got anything with more than two
processors?
gcooper
"Hal Gwin" <
message
href="news:916C2893C79AD6A66AB679C93D2F275F@in.WebX.maYIadrTaRb">news:916C2893C79AD6A66AB679C93......
one hand with enough fingers left over to hold a cup of coffee. When
ever I work on IDWs I switch IV back to both processors. All my other
apps run on the other processor, however the OS will not let you change the
affinity for some of the services that are running.
face=Arial size=2>
Hal Gwin
Mechanical Designer
Xenogen
Dell 650
Dual 2.66GHz
Xeon
1.5GB DDR RAM
Quadro4 900XGL
nVidia 6.13.10.4072
Drivers
"Matt Stocking" <
wrote in message
href="news:9BEB38C48DEED320CCE45BF42D1BAB21@in.WebX.maYIadrTaRb">news:9BEB38C48DEED320CCE45BF......
affinity's
would make you machine act like a single cpu.
size=2>Matt
"Matt Stocking" <
wrote in message
href="news:7720FED6B72B3CB7121288E8F9161975@in.WebX.maYIadrTaRb">news:7720FED6B72B3CB7121288E8F91......
win2k server supports 4+ processors.
Matt
"gcooper" <
message
href="news:7EDA972DE41D2E7060970C41D768D4B9@in.WebX.maYIadrTaRb">news:7EDA972DE41D2E7060970C41D......
processors?
gcooper
"Hal Gwin" <
in message
href="news:916C2893C79AD6A66AB679C93D2F275F@in.WebX.maYIadrTaRb">news:916C2893C79AD6A66AB679C......
been more stable running on its own processor. I can count the
number of crashes I have had in IV since I got my new machine (about 4
weeks ago) on one hand with enough fingers left over to hold a cup of
coffee. When ever I work on IDWs I switch IV back to both
processors. All my other apps run on the other processor, however
the OS will not let you change the affinity for some of the services that
are running.
Hal Gwin
Mechanical Designer
Xenogen
Dell 650
Dual 2.66GHz
Xeon
1.5GB DDR RAM
Quadro4 900XGL
nVidia 6.13.10.4072
Drivers
"Matt Stocking" <
wrote in message
href="news:9BEB38C48DEED320CCE45BF42D1BAB21@in.WebX.maYIadrTaRb">news:9BEB38C48DEED320CCE45......
affinity's
well this way, thats why there is an affinity setting.
size=2>Matt
"MechMan" <mechman> wrote in messageThe
href="news:f1449a6.7@WebX.maYIadrTaRb">news:f1449a6.7@WebX.maYIadrTaRb...
RAM limitation will become more trivial when 64bit software becomes
mainstream. Would be quite a CAD station where each CAD system had it's own
CPU to run on. That would be a workaholic's CAD
station.
MechMan
