Drop down menu for Material, Appearance and others don't stay open Inventor 2022
frahaman7SKBG
frahaman7SKBG
Below is an Screenshare of what I mean. Any of the drop down menu does not stay open.
Screencast link:
https://autode.sk/3brZCpi
Gabriel_Watson
Check if your 3D mouse is being pressed/displaced, or any keyboard arrows/keys are stuck in pressed down mode.
frahaman7SKBG
Hi @Gabriel_Watson ,
This happened after I applied the solution you have provided for the dialog box resizing on this forum.
https://forums.autodesk.com/t5/inventor-forum/unable-to-resize-dialog-box/m-p/10712225#M844737
I think it has to do with the graphics of Inventor 2022.
Gabriel_Watson
Which of the solutions? Do you mean solution two as the "checkmark Software Graphics under Tools (tab) > App. Options > Hardware"?
I have come across glitches like this one in the past, but typically where the Appearances/Materials lists would disappear but could still be scrolled through (one item showing at a time). That would fix itself after closing and re-opening Inventor.
If your issue persists I would try this similar fix someone found for Fusion 360, which indicates it could be a Windows setting issue:
https://forums.autodesk.com/t5/fusion-360-support/drop-down-menus-disappears/td-p/8792498
Try also disconnecting/unplugging any wireless mouse and reconnecting it after 10 seconds.
Do you use multiple monitors? Long-shot but maybe the display scaling has something to do with it:
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-dr...
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/grip-m...
frahaman7SKBG
The solution you said " Inventor shortcut on your Desktop and go to Properties > Compatibility > Change high DPI settings > checkmark "Override..." and pick "System (Enhanced)". To fix the dialog box resizing issue.
Currently Im using how you have described (selecting one at a time) using the down arrow key.
I will go thru your list of suggestions and will report back to see if any of them solved the issue.
thanks again for all your help.
