Inventor Forum
Driven constraint
8 REPLIES 8
Message 1 of 9
648 Views, 8 Replies
Driven constraint
Is it possible to drive two constraints at once? I have a part that I want to record in an avi file both rotating & telescoping. If not possible to record both constraints moving at the same time can I at least record one moving then the other in the same avi file? Thanks in advanced.
Driven constraint
8 REPLIES 8
Message 2 of 9
do a min and max formula
Message 3 of 9
Search the NG for Animator 2.5 it will allow you to
drive two or more constraints at the same time.
Kathy Johnson
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
do
Kathy Johnson
do
Message 4 of 9
Check out Sean Dotson's Animator add-on.
www.sdotson.com
MechMan
www.sdotson.com
MechMan
Message 5 of 9
You might want to look into Sean's free Animator program. www.sdotson.com
Kent
Member of the Autodesk Discussion Forum Moderator Program
"garney" wrote in message news:f121903.-1@WebX.maYIadrTaRb...
Thanks in advanced.
Kent
Thanks in advanced.
Message 6 of 9
Animator is the easy way to do it (by the way it's
Sean AND Neil's program <g>)
I also have some tutorials on my site on how
to do it the hard way.  Look under Advanced Motion Part 1 and
2
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak..
Is
advanced.
2
Sean Dotson, PE
...sleep is for the
weak..
Is
advanced.
Message 7 of 9
Sorry Neil Munro.
MechMan
Sorry Neil Munro.
MechMan
Message 8 of 9
I've not played with Sean and Neil's program, but
you can easily drive multiple constraints with plain Inventor.
It involves making one constraint use a parameter
of another: for example, your rotation is .7 x your mate offset...
Then you drive one constraint and lots of things
happen.
The constraint you drive could even be between two
hidden components.
G
happen.
hidden components.
G
Message 9 of 9
You mean after all this time I've been begging you
to put something like this built into Inventor and you still haven't taken a
look?
You are probably goofing off doing stuff like
fixing R6.  Jeeze <vbg and gd&r>
Take a look when you get a chance....
Sean Dotson
...sleep is for the
weak...
offset...
happen.
two hidden components.
G
look?
Sean Dotson
...sleep is for the
weak...
offset...
happen.
G
