Inventor Forum
Drive constraint in 2013
7 REPLIES 7
Message 1 of 8
jrapert
2718 Views, 7 Replies
See attached screen shot.
To activate the new position of the assembly of approx 5k instances takes about 5 minutes in IV 2013 when using Drive constraint. The larger the assembly the longer it takes
In IV2011 takes about 10 seconds.
I've never seen the "Not responding" sign in Drive constraint window in previous versions.
I'm just wondering how can avoid this "New feature" of 2013.
Is anybody experienced this ?
Julian
7 REPLIES 7
Message 2 of 8
jrapert
in reply to: jrapert
Forgot the specs:
IV2013 Design Suite Premium
Windows7 Ultimate
12 GB RAM
1 GB NVidia Quadro 3700M graphics card
Message 3 of 8
blair
I have seen this as well in IV2013 on my systems. I don't recall it happening in IV2012. It seems like it gets lost trying to return the model back to the starting point/position.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 8
Yijiang.Cai
in reply to: blair
I used one sample to experinece this, and it can't be reproduced. So could you attach the dataset for more invesigation?
River Cai
Inventor Quality Assurance Team
Email: River-Yijiang.Cai@autodesk.com
Message 5 of 8
jrapert
in reply to: Yijiang.Cai
The data set is too large to attach, also contains some proprietary details I can't disclose.
As I mentioned this issue only significant with large assemblies (5-10000 parts), but similar assembly in ver. 2011 did not have this problem. Seems to me that large assembly handling in 2013 is different to previous versions, and some operations significantly slower
Message 6 of 8
johnsonshiue
Hi! Without the dataset, it is extremely hard to tell where the problem is. I can provide a secure site for you to upload the large file. Please let me know via email if you would like to share.
In the meantime, could you help me answer the following questions?
1. What are the default settings in Tools->Application Options->Assembly in R2013 on your machine?
2. Could you try opening the same assembly and do Rebuild All (Manage -> Rebuild All)? What do you see?
3. Could you change Hardware setting to Compatibility mode (Tools->Application Options->Hardware) and see if it helps speed up?
Thanks!
Software Test Engineer
Message 7 of 8
jrapert
in reply to: johnsonshiue
Hi Johnson.
Thank you for your help
1 The default setting is as per attached screenshot. I've tried with different (unchecked) setting with no difference.
2 I've done  Rebuild all with no apparent problem in approx 5 minutes.
3  I'm running in Performance mode, tried Compatibility with no difference.
I'm sending you an email regarding the data set
Julian
Message 8 of 8
Can you try to uncheck the "Enable related constraint failure analysis" option and see whether it helps.
You could also try to increase the Page file size in Windows and Undo size in Inventor under Application options.
Hope it helps.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Autodesk Customer Advisory Groups
