I'm in the same boat .... work for a German company, and we have German everything. However now we have an American HQ. So I've been working on an Ilogic code to flip everything.
There are Ilogic codes out there for sheets and Titleblocks. The sketch symbols was the hard part.
It's not a simple task for 2 languages,, I'd hate to see if it was more than 3.
So basically what youre saying is, that I can create 1 drawing and through iLogic make the switch between languages in iProperties and Title block?
You can ilogic change out Titleblocks ...
Not sure what you mean for Iproperties without seeing them ... So I can't say 100% yes to that. But you should be able to do swap's if Iprop = A, then change to B ...
I know that you are using Inventor.. But another option (you would have to test).. Is to export it to AutoCAD drawing and then use the COINS translator add-in (its free).. https://apps.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3aCOINS-Translate%3a...
There are other language add-ons in the AutoCAD Exchange App store for AutoCAd but I have used the COINS before and it seems to work pretty good.
There is one for Inventor https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com%3afx64translatio... you may want to look at but there's a cost assoicated to it.
Mark Lancaster
& Autodesk Services MarketPlace Provider
