I have an enclosure with a hinged door. I would like to show this in a drawing with the door open and with the door closed.
I thought I could create a "view" for each but that does not work. The position of the door is not really a "view" but more of a location or orientation.
Is there a way to show both positions on a drawing?
Thanks, Steven
Solved by swalton. Go to Solution.
Create an "open" and a "closed" position representation in your enclosure assembly. Create two views in your drawing. Set one view to use the open position rep and the other to use the closed rep.
See: http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-C728DFAC-1B45-4879-A004-45A8DC991954
and http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-CF281376-D641-4988-B0B6-CD1E3C31ED8E
Steve Walton
