Inventor Forum
Drawing View Thread Feature used to be on by default
8 REPLIES 8
Message 1 of 9
2710 Views, 8 Replies
Is it just me, or did the Drawing View Thread Feature option get switch to default OFF, where it used to be on?  Did I do something on accident to make this happen?  Does anyone know how I can get it back by default?
All views and no threads makes Jack a dull boy
All views and no threads makes Homer something... something...
Not that it's driving me crazy or anything Smiley Frustrated
8 REPLIES 8
Message 2 of 9
mcgyvr
I think you might have it backwards..
I don't remember it being on in previous versions but its checked by default now with 2014 SP1..
Or Obi-Wan Kenobi is doing that Jedi mind trick again..
Message 3 of 9
Your reply gave me a clue.  My 2013 default.idw had threads shown by default, for sure.  I used that template when I moved to 2014, never bothering with modifying the stock template.  When Inventor 'migrated' my old template it seems to have made the executive decision that I should have threads off by default.  I protested, but was unheard.  Opening the 2014 stock template shows threads by default.
Thank you, Autodesk, for providing me with the opportunity to study every change I made to my default template as I completely rebuild my it from scratch.  Not allowing preferences to be configurable is a wise approach to designing technical software.  It is a very good use of my time.
2+2=5
Message 4 of 9
Mojo this is hitting me now going from 2014 to 2015. Did you ever stumble across the magic solution to why this happened?? Thank you!
Here's my post: http://forums.autodesk.com/t5/Inventor-General/part-base-view-quot-Diplay-Option-gt-Thread-Feature-q...
Message 5 of 9
Sorry, no.  I had to remake my templates, too.  I haven't installed 2015 yet.
Message 6 of 9
Best of luck.
Message 7 of 9
t_pcoll
Threads checkbox default is not related to templates, it's related to Base view dialog only - no need to recreate templates. In 2015 some Base view dialog settings are remembered (even across sessions) - simply, when creating view of an IPT the Threads option should default to the same status as previous IPT view was created with.
I hope this helps.
Ladislav
Message 8 of 9
in reply to: t_pcoll
Thanks for your input, Ladislav.  I'm not certain the 'should default to the same status as previous IPT' is doing what it should.  Please check against this workflow:  create a fresh drawing template in 2013, which will have threads shown on by default.  Make a part with threads.  Make a base view of that part in 2014 using the 2013 template.  I expect you'll find no threads.  Apparently if you bump this up a year you'll see the same thing.
Message 9 of 9
mrattray
