Drawing View - Grid Lines/Rulers
blair
Mentor Mentor
blair
Is there a toggle/switch to allow for Rulers/Grid lines within the drawing IDW module. It would help with the alignment of drawing/dimension items (balloons, text, dimensions). Yes, I know about snap-dragging Balloons from another Balloon for alignment.
Or is this a feature request/enhancement that should be posted on the Inventor Idea's page.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Raeez.Abrahams
Observer
Observer
Alternatively you can create a sketch in your idw and constrain your annotations to the sketch you have created.
blair
I guess this would work if you create a grid pattern of Horizontal and Vertical lines on the sketch you create so that you have something to work with using the annotation tools within the IDW environment.
Not really a solution, it would be faster to pan the drawing so you can use the edge of the monitor as an alignment guide.
Delta Tau Chi ΔΤΧ
johnsonshiue
Hi! There isn't an out-of-box option to do that. I have heard this request before though. You could create a sketch symbol so it can be reused in the future. You can make it invisible afterwards.
Many thanks!
Software Test Engineer
Fouad-l
Sometimes i use a free & open source app called "Meazure" to show a grid on the display for other drawing Apps (Windows OS). Maybe can help for Inventor too.
Link : http://www.cthing.com/Meazure.asp
Grids dimension can be  changed from Tools - Display grid spacing.
Grids color can be changed from Edit - tools - lines - color
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
NigelHay
I tend to just drag the drawing area to the edge of the drawing window & use the vertical & horizontal edges for alignment.
blair
Thanks, I'll take a look at it
Delta Tau Chi ΔΤΧ
