Is it possible to get parts Vault revision number to show in text field or in parts list?
Solved by mikko.m. Go to Solution.
Solved by mpatchus. Go to Solution.
Simply add the REVISION NUMBER property to your Parts List definition.
Does it read the revision number from the model or in the Vault this way?
Or is it possible to get revision number from Vault to title block somehow.
Adding REVISION NUMBER works after it's mapped properly in Vault.
This video was helpful:
