Hi people,
I Hope everyone is doing great !
Small question here :
I made a sketch symbol for specific welding symbols I couldn't find in the library.
Problem is the symbol is hiding his own leader like so (quick exemple) :
What I whould like is the leader to go to the small red "x" wich is the insertion point. Is that possible ?
Thanks and best regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"Hi Laurent,
Is the cirkel the only thing you added to specify you symbol?
Because you can find it here:
No. This is a quick exemple to demonstrate the issue.
If this post helped out in any way to solve your question, please drop a "Like"CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
Hi Laurent,
I am not sure if this is what you want. Try deleting the leader and then add it back. By default it should be placed at one end of the symbol. You may not get the exactly position but it should be close.
Please feel free to share the symbol so forum experts can help take a look.
Many thanks!
