Drawing Shaded view (polygon curves)
hugo.trepanier
Message 1 of 17
hugo.trepanier
Very strange behavior. Since updated inventor 2017 to 2021 drawings shaded view lost precision.
All elbow "curves" appear polygonal and the bitmap resolution is on the maximum. see picture
Hugo Trepanier
Autodesk MSD Application Specialist
Replies (16)
Message 2 of 17
jtylerbc
Probably so obvious that you've already tried it before posting here, but I'll ask it anyway just in case it was overlooked.
Are your graphics drivers up to date?
Message 3 of 17
mcgyvr
Or how about.. Tools application options..hardware tab.. check the box for "use software graphics" the restart Inventor?
Or have you tried right clicking on the view and select "make view raster" and then right click on it again and select "make view precise?
Message 4 of 17
hugo.trepanier
All is up to date, all views are precise, tested with software graphic and problem remain on all computers with different graphic card "Quadro"
Hugo Trepanier
Message 5 of 17
JDMather
Can you Attach the files here?
(Only need the Elbow, Assembly and Drawing - verify that after removing the extraneous stuff that the behavior persists.)
Message 6 of 17
hugo.trepanier
Files uploaded
Hugo Trepanier
Message 7 of 17
JDMather
Open the Elbow.
Go to Manage>Rebuild All and then save.
Go back to the drawing and you will get a Update view message.
(I had to do this with the other parts as well.)
Not sure why this works or exactly what the issue was.
Message 8 of 17
hugo.trepanier
Thanks for your help, I will open an Autodesk case, it's a very weird problem...
Hugo Trepanier
Message 9 of 17
johnsonshiue
Hi Hugo,
I am also on 2021.2. Here is what I saw. Please make sure all critical Windows updates are installed and graphics driver is updated. Another thing to try, right-click on the view -> Make View Raster. Then repeat it but select "Make View Precise." Does it look better now?
Many thanks!
Software Test Engineer
Message 10 of 17
hugo.trepanier
The only way to resolve the problem is to do a Rebuilt all on the piping run subassembly. I tried to update the piping run on the design data piping folder and also rebuilt all because a suspect that the problem was in this file but I need to rebuilt all each time when I create a new run.
Hugo Trepanier
Message 11 of 17
johnsonshiue
Hi Hugo,
Another possibility is the elbow ipt or the iam file may have an option unchecked. Go to the top-level assembly -> Tools -> Doc Settings -> Modeling -> check "Maintain Enhanced Graphics Detail." You may need to do Rebuild All once and save it. After that, it should persist.
Many thanks!
Message 12 of 17
hugo.trepanier
Hello Jonson,
The settings  "Maintain Enhanced Graphics Detail" is already checked. I opened an Autodesk case yesterday with all details, CaseNo:17268494. It's a very strange behavior that I can reproduce on more than one computer
Hugo Trepanier
Message 13 of 17
johnsonshiue
Hi Hugo,
One more thing to check. Go to Tools -> App Options -> Hardware. What is it set to? Mine is set to Quality.
Many thanks!
Message 14 of 17
hugo.trepanier
Hello Johnson, Yes same for me. The problem is now on the Autodesk development, they are able to reproduce this problem 50% of time. The actual workaround is the rebuilt all of the piping assembly. Thanks
Hugo Trepanier
Message 15 of 17
hugo.trepanier
Hugo Trepanier
Message 16 of 17
johnsonshiue
Hi Hugo,
Do you mind sharing the defect ID or case ID for future reference purpose?
Many thanks!
Message 17 of 17
hugo.trepanier
Hello Johnson, the case number is 17268494.
Thanks for your help.
Hugo Trepanier
