Drawing. Section View. Bug?
Vadim-the-Engineer
Vadim-the-Engineer
When inserting section view of one of the views (main / projected / detailed...) willing to show part from the middle of the web (section E - E) of the IPE profile I still receive the "back" flange on the view even if the line clearly shows where it should start the section... Another issue is the "I" profile appearing in the same section view (blue rectangle) that is not in the model at all...
Inventor 2017.4.2
Attaching drawing + ass'y + parts: CatWalk.rar
PaulMunford
Check that the I beam part is able to participate in sections.
Could the T beam in the background be a hidden line view?
Paul Munford
Technical Onboarding Architect
Linkedin
Vadim-the-Engineer
***Check that the I beam part is able to participate in sections. ***
Meaning? NOT EVERY component can be section-viewed? It is not zero-thickness nor shell nor surface... (which will be legit reason)
***Could the T beam in the background be a hidden line view?***
There are no hidden components except skeleton sketches (by toggle visibility)
MikeKovacik4928
right click the relevant part under the IDW browser and check whether the section participation is on. It looks like it has been switched off.
See attached
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Vadim-the-Engineer
Thanks for the solution! Probably saved me couple of hours trying.
MikeKovacik4928
No problem, Vadim.
Glad I could help
Mike
