- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dearest Inventor Gurus,
A longstanding but minor irritation for my drafting department has been the slash in the scale call-out in drawing views. We feel it should be a colon. "SCALE 1 / 2" vs. "SCALE 1 : 2" Now, I know I can go and change the list of Preset Values scales in the Standard Styles, but that is not a true solution as the Detail views slip through the cracks. As desirable as it is to keep the scale a base two, sometimes it is necessary to throw a three in there such as 1 : 6, 1 : 36, or others not in that default scale drop down menu. When that happens and a detail view is placed, the slash will pop up again as 1 / 3 or 1 / 18. The idea of having an exhaustive Preset Values list is a bit ridiculous to me. Also, I would rather not change from the base international standard ANSI because that affects a multitude of aspects that have been painstakingly set over the years - not a great trade off. But if that is the only option, I would consider it. Being at my wit's end I pose this question to you, great minds:
Is there some way I can burrow into the APT ANSI 2013 (yes, that's a year in our standard T.T) and get it to default with a colon in a given scale rather than a slash?
I would also accept an iLogic solution.
The image below is where I'm at now. The Preset Values list has been trimmed down from including 1 / 2, and 1 / 4.
