Drawing Resource Transfer Wizard error
mluterman
Advisor Advisor
mluterman
When I need to use it, I close Inventor, wait about 10 seconds and click on it. But I get this error every time now. And most of the time, I can't even end the Process in Task Manager because the Inventor Process already ended and is not on the list of running Processes. I have to reboot to use it now. Anybody have any ideas?
Gabriel_Watson
Try closing Inventor by killing its task manager process instead of a normal close, while it is still open. See if it makes any difference. I'd also check for any add-ins or iLogic still running in the background if you had loaded anything.
mluterman
Thank you so much! Disabling the non-Autodesk add-ins did the trick! (Since it wasn't showing up in Task Manager as a running Process).
