Drawing - overlay view transparency
w.poortinga
w.poortinga
For assembly instruction purposes I'm using the Overlay function in a drawing. When creating one, the part I intentionally gave a shaded view to show that it's the part that you need to mount next, becomes transparent for some reason (see red). The part also shows through the non-shaded parts of the assembly (see blue).
Is the any way to change this? If possible I'd like the part to be shaded and besides that, for the assembly to behave like it usually does. Maybe there's another way to achieve this?
blandb
Does the link below help you?
http://inventortrenches.blogspot.com/2017/02/issue-you-want-to-create-view-on-your.html
Autodesk Certified Professional
johnsonshiue
Hi! I could be wrong but it looks like a bug to me. Have you installed the latest updates? If yes, please share the files here or send them to me directly (johnson.shiue@autodesk.com). I would like to understand the behavior better.
Many thanks!
Software Test Engineer
w.poortinga
Thanks for you reply. This is they way I tried (and I tried alot of other options too, switching the base and the overlay view representations etc.). I always end up with this problem unfortunately.
w.poortinga
Hi Johnson,
Thanks for your quick reply. I did indeed install all the latest updates.
That would be really unfortunate! I'll send you the files in a minute. Thanks for looking into it.
And just for my information; in your opinion it is supposed to look like the picture below? Or is an overlay supposed to be seen over and through the base view parts? Which would make some sense actually (unfortunately for me) judging by the name 'overlay' Smiley Tongue
William
johnsonshiue
Hi William,
Many thanks for sending me the files! Like I mentioned in the email reply, there is still a part missing. Please send the part to me. I will take a look and understand the behavior better.
Thanks again!
