Doing so is a negation of an associative, parametric design software. I've
done so under duress, changing the color in the hope that I would never
damage myself by putting out a drawing with an incorrect dimension on it.
It should embarrass Autodesk that it fosters such a shoddy, even by
yesteryear standards, practice. There are so many ways to deal with the
requirment in an adequate (@dXX), if not elegant (show model dim or
annotation), manner. So much for leading edge technology. Roll eyes,
shake head, go for beer.
"Larry Caldwell" wrote in message
news:4885328@discussion.autodesk.com...
Yep ... can be done I suppose, but sounds like something other then sound
documentation practice to me. Hope I don't ever get to where I think
overriding dims is a good idea.
~Larry
"Hugh Henderson (Autodesk)" wrote in
message news:4885030@discussion.autodesk.com...
Stephen is correct. We don't support 3D dimensions in an iso view.
You can ovveride the value by:
1) Double-click the dimension on the value
2) In the Dimension Tolerance dialog, check the override value checkbox
3) Enter the desired value and OK
Hope this helped...
Best regards.
Hugh Henderson (SQA Engineer)
