Drawing, dimensioning keyway depth in a hole
checkcheck_master
Message 1 of 11
checkcheck_master
Hi there,
See picture, on a drawing, is it possible to dimensioning the keyway depth(4.5 mm) without having the sketch with the arc?
2021-04-19_210530.png?
Greetings!
Replies (10)
Message 2 of 11
johnsonshiue
Hi! I am sorry I am not sure I understand the request. Why is the sketch arc needed here?
Many thanks!
Software Test Engineer
Message 3 of 11
checkcheck_master
Hi John,
I can not get the 4.5 mm in a dimension unless I place a sketch with an arc in it to refer to.
Greetings!
Message 4 of 11
Rethceif-Nick
The way you have the keyway dimensioned, there is no way to get around it without some reference geometry (sketch) of some type. Or you could manually change the dimension to the correct spec.
A more proper way to dimension the keyway is from the bottom of the bore to the top of the keyway. Then you could use a reference dim for the depth, just overide the dimension to display the correct value.
Message 5 of 11
mcgyvr
@checkcheck_master wrote:
Hi there,
Greetings!
@checkcheck_master  Yes there is... Start the dimension command.. Pick the ID/radius then the vertical line of the keyway THEN go back and hold your mouse over the tangent point you want and it should popup and allow you to now select that for your dimension point..
Message 6 of 11
checkcheck_master
Thanks Brian, exactly where I was looking for!
However, if the yellow mark does not fall on the black tip, it is very hard to see on my monitors, see pic.
I'm concerned that Inventor has more of these hidden tricks that I'm missing.
Is this documented in the help? I can't just find it.
Greetings!
Message 7 of 11
ENGi3
Observer
Observer
How does one dimension a keyway in inventor. the dimension should look like this
but it keeps forcing me to the center of the circle like in the pictures in the comments above. I would like to be able to dimension to the furthest point from the keyway flat. I try to make my dimensions ones that can actually be measured with calipers directly.
Message 8 of 11
blandb
Should just be able to select the line and move cursor to the bottom quadrant and click on the node that appears.
Autodesk Certified Professional
Message 9 of 11
ENGi3
Observer
Observer
If the flat were parallel to one of the principal planes that does work. However, the flat on my part is at a weird angle (37.9 degrees) and that does not work. I was hoping to just select the flat and the circle and have the option on the circle to have the leader go to nearest or furthest distance from the flat on the circle, or center of the circle.
Message 10 of 11
blandb
@ENGi3
Is below what you are referring to?  This is 2026 I don't remember if previous versions would pick up the tangent like this, but hover over what would be around the tangency of the circle and look for the tangency glyph...Please see attached. If that doesn't work, you could start a sketch on the drawing view, project the circle and flat, make a line parallel and tangent, then dimension that in the drawing.
Message 11 of 11
ENGi3
Observer
Observer
Thanks, that worked perfectly. I was not cognizant of the constraint icons while dimensioning the part. Your input was very helpful.
