- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have an assembly made using the Frame Generator feature. Within that assembly file I have created some view representations. These view representations are used to create a drawing package. I added breaks to some of these drawing views to fit them on the page.
The problem I am having is that whenever the parts within a view representation move within the assembly (I am changing other part lengths and am not modifying any of the actual parts within the view representation), the center location and length of the drawing view break changes such that important information is cut out and/or the drawing no longer sits entirely on the sheet. Is there any way to avoid needing to fix every drawing sheet every time the assembly is edited? Does anyone know if this is an issue outside of frame generator assemblies? This problem even happens when I just move an un-grounded assembly relative to the origin point without editing any parts.
I am not using the custom position representation feature, only the basic top/front/right views in the drawing package.
I have tried using the lock feature on the view representations but that does not appear to help this issue.
I am currently running 2022.1.
Ryan
