Inventor Forum
Draw a dome in sketch tool
5 REPLIES 5
1534 Views, 5 Replies
Hello everyone,
I work on a project I have to draw a dome (Skydome)
the shape is special,
the base is rectangular and the roof is slightly bent towards the center.
I do not know which functions to use, it should look like this.
thank you in advance for your help
5 REPLIES 5
JDMather
I would use Loft or Patch.
Can you attach your *.ipt attempt here?
Curtis_Waguespack
I'd do a loft.
Cadmanto
Ralph,
It looks like you have 4 separate panels.  If that is the case the middle 2 can probably be done with simple extrudes with the contoured shape.  The outer 2 I would go with which has been suggested and that is to create a sweep.  But before doing the sweep, I would create sketches to formulate the basic shape you need.  Then once you have it, you might be able to simply thicken the surfaces to get your solid geometry.
Hope this makes sense.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Paul-Mason
in reply to: Cadmanto
something like this :-
The ipt file is attached.
Inventor 2025 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
